Amplifier and speaker compatibility
mcaoile
I recently brought a home theater system from a friend. It's already an old set-up. Setup is below.
Onkyo TX-NR838
Infinity Kappa 70 (Front) 20-200W @ 6ohms
Jamo (Surround) 140W @ 8 ohms
Yamaha (Surround) 120W @ 6 ohms
Jamo C9 (Center) 140W @ 6 ohms
Yamaha (Subwoofer) 250W
I found some specs for the amplifier (130W 2ch 8 ohms; 180W 1Khz 6 ohms IEC; 215W 1Khz 6 ohms JEITA)
Are the speakers alright with the amplifier?
Thanks
Onkyo TX-NR838
Thanks
Should be, but it ultimately depends on the maximum SPL you listen to and your distance (main listening position) from the Kappa 70.
Teetertotter?
Teetertotter?
Why don't you set everything up and see how it sounds to your ears. You just might be amazed! Everything looks good.
stalag2005
Most amplifiers built in have enough power to drive most speakers without issue. I don't see any exceptions and the Onkyo should be able to put out enough for reasonable amplification given the speakers mentioned.
Don't get too hung up on the various speaker wattage specs, the maximum wattage of a speaker is a guideline for damage, not much use other than that and the nominal impedance is only so meaningful compared to seeing the actual measurements across the frequency range. Speaker sensitivity tells you a lot more, use an spl calculator to see that relationship Peng mentioned with distance from the speakers and your desired levels The wattage of the sub's amp doesn't mean anything in relation to your question as the avr does not supply the power to the sub (unless you have a passive sub with no amp built in, then the receiver just won't work with that kind of sub, it would require an active/self-powered sub).
