So last night I bought the Crown xls 402 amp. Im running 2 Subs @ 300RMS a piece. I connected it all and it worked fine for about 15 min. I called it good and went to sleep. Today I get home from work and decided to listen to some music. I turned the level controls from half way to about 2 clicks higher and it played for a min longer, then the subs went silent. I checked the breaker and sure enough I had to reset it, so I did. Turned the knobs all the way down and attempted to turn the amp back on. The green signal lights flashed on and off and nothing more. If I wait a few min and try again the lights will flash again but the power light will never turn on. What have I done? I have tried completely disconnecting everything, Ive let it sit for a good hour unplugged with the power button in the off position and it still wont work.
