I would recommend using a 450 for the center as well. Since music is the majority of your listening, the center being 100% matched to L/R will give you a 100% seamless front soundstage. As a bonus, it will be cheaper than the CLR2002
You can get the XPA-3 for L/C/R and use the receiver for surrounds. Once you calibrate the system and have level matched the speakers, it will be as if the external amp did not exist in the chain.
