The LE-109s have a sensitivity of 89dB so they don't require high power to drive them. The DRA395 is not high power but in a normal room it should drive the LE109s fine @ reasonable volume levels.
Wow..
Those SP3005 are vintage, typical loudspeakers brought back from the Orient during the 70s.. They are very efficient, not much power to drive.. But likely too boomy with the 15" woofer..
Audio-wise I would venture to say the Cantons will deliver a more balanced, sound.
Try each and decide..
Just my $0.02...
