agarwalro said:
Make sure you use the "Pre-Out" connections on the receiver and NOT the speaker connections to transfer signal from the receiver to the amplifier's "RCA In" connections. From the amp you will use the speaker level connections to take signal to the speaker. The connections should be done as follows,
Receiver Pre-Out connection -> RCA cable (line level signal, low current) -> Amplifier RCA In connection
Amplifier Speaker terminal -> 14 gauge Speaker wire or lower (speaker level signal, high current) -> Speaker terminal of same color
Yes
Your Receiver should have Pre outs for all your channels
Front , left and right = 4 preouts
Surround , left and right = 4 preouts
Center , Front and Back = 2 preouts .
So you should have in the back of your Yammy 10 pre out jacks that go to your HK Amp , thats a total of 5 sets of Rca jacks running into your amp from your pre .
Also it does matter , in your RCA jacks , get half decent ones dont use the cheapo ones .
In speaker wire , i found a big difference in the Montercable XP over the regular stuff , beleive it or not . Its much clearer .
