Amp needed for ELAC Uni-fi UB5
Best amp for ELAC Uni-fi UB5 that cost less than the speakers ($500)...
  • Emotiva A-150
    Votes: 0 0.0%
  • Other... (Explain)
    Votes: 0 0.0%
  • Total voters
    2
Greg83
Greg83
I just got my ELAC Uni-fi UB5 for my front left and right channels. I have an 11.2 channel system (no bouncy house speakers). I was going to get the emotiva a-300, but idk if that would be overkill. Should I just get the a-150 instead? I don't mind paying the extra 100 bucks for the a-300...
KenM10759
KenM10759
I don't see any A-150 on their website. Strange.
The A-300 is 150 w/ch, so unless you were really topping out the speakers and not running a subwoofer it's going to have plenty of headroom. Like a motor in a car, I don't know that anyone has ever regretted having a little extra power on hand. It'll run cooler than a taxed amp of half the power (if that's what an A-150 is.)
BTW, if you would ever upgrade to bigger/better speakers the amp will handle it easily.
Greg83
Greg83
I'm new at this so forgive me if I say something way off. These speakers are 4 ohm. They are rated for about 140 w/ch. The a-300 puts out about 300 w/ch @ 4 ohm. I know a little extra power never hurt anyone. I just didn't know if double the power was okay. I guess I could just always turn it down if needed. I do have two powered subs. You have a good point saying it's future proof. Thanks for the input.
P.S. - The A-150 is half the power of the A-300, but it's only $100 less.
slipperybidness
slipperybidness
That speaker 140W rating is pretty much useless and can safely be ignored.
The 4ohm rating is a much more useful spec to match to a proper amp.
A-300 would be fine. You didn't mention what receiver/pre-pro you have so, can't really comment on whether or not it would be necessary, though it certainly won't hurt.
KEW
KEW
I agree, unless you are extremely strapped for cash, the extra $100 is well spent on knowing you are not going to clip your amp (or send a clipped signal to your speakers) as long as you are sane with volume control.
