Amp for LFE Shakers
jaxvon
jaxvon
I plan on getting some LFE shakers at some point for the system I'm putting together, but I'm at a loss of what to get to amplify them. I know a nice distributed audio amp would work, but those are expensive and it seems like such a waste of quality just to send 30w to a moving weight that shakes the couch. Any ideas?
RLA
RLA
Hello
If you are on a tight budget an old receiver will work to drive a pair of
Aura type accuators If you are going to install Clark or Buttkicker Try to save for the Butkicker amp Its feature set and build quality is outstanding for the $
range of 5 - 200 Hz.
ButtKicker Amplifier Specifications
Model #: BKA1000-4
1100 Watts @ 4 ohms
2100 Watts @ 2 ohms - will power 2 ButtKicker LFEs wired in parallel, and 4 ButtKicker LFEs used in individual home theater seats.
1050 watts per ButtKicker when two units are wired in parallel
Class D switching technology
Variable high cutoff, 40 to 160 Hz
Low cutoff, 25 Hz switchable
RCa RCA and ¼” inputs with 160mVolt and 1.25 Volt sensitivities eliminates the need for a separate pre-amplifier
Five way binding post output
115v – 230v, switchable, worldwide usage
Convection cooling, i.e. no fan
12"W x 11"L x 4.375"H,
25
