Amp choice and/or passive bi-amping for ML hybrid electrostat?
KEW
KEW
This regards my Martin Logan Vista'a.
I know the general wisdom is passive bi-amping is a waste of time/wire, but wanted to make sure the electrostat speakers don't alter that equation.
The design is a 8" ported woofer module with a "Vojtko" (whatever that is - the designer?) crossover at 450Hz to the electrostatic panel.
Unfortunately, I cannot find an impedance graph for the Vista.
The manual states 4 Ohms Nominal and 1.2 Ohms minimum at 20kHz and sensitivity of 90dB/2.83 volts/meter.
The manual recommends a 100 - 200WPC amp, then goes on to say "it is important that the amplifier be stable operating into varying impedance loads: an ideally stable amplifier will typically be able to deliver near twice its rated wattage into 4 ohms and should increase again into 2 ohms."
That is a pretty high bar and I'm not sure my XPA-2 gets me there, so I am wondering if I should use my 5 channel Monolith instead (either in stereo or 4 channels to passively bi-amp), or neither of the above!
Here is a link to a review by Home Theater Review (no measurements) if anyone is curious:
https://hometheaterreview.com/martinlogan-vista-hybrid-electrostatic-loudspeaker-reviewed/
Y
yepimonfire
That is a pretty high bar and I'm not sure my XPA-2 gets me there, so I am wondering if I should use my 5 channel Monolith instead (either in stereo or 4 channels to passively bi-amp).
Might need to go with pro gear to handle that severe of an impedance dip.
everettT
everettT
The lowest impedance dip on almost all hybrid MLs is very high in th FR and with no difficult phase angles. Yours is 1.2 @ 20khz. Most any amp will drive them (as noted on esoteric forums, with an somewhat equal split with tubes and ss amps). If it where a full range electrostatic panel only, I'd imagine then a stout amplifier would be in order. When I had my older Ascents I used a 140wpc B&K that had no issues.
