Hey everybody
I bought a pair of PSB Image T55 towers recently and have been using them with an old Sony receiver model STR-DE405. Its something that was already in the house from years ago so I just connected it up thinking I'd wanna upgrade anyway. But it sounds good, the speakers can rumble the house if needed, and I dont feel like like Im missing anything. BUT, we all know you don't know what you're missing until you try something better
With all that said, would I really get much benefit from getting an amp/preamp combo or even an integrated amp? I was thinking something from NAD most likely... but should I bother?
What do you guys think?
Image T55 specs:
Frequency Range
On Axis @ 0° ±1.5dB 45-20,000 Hz
On Axis @ 0° ±3dB 32-23,000 Hz
Off Axis @ 30° ±1.5dB 45-10,000 Hz
Lf Cutoff -10dB 28 Hz
Sensitivity
1w (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted
Anechoic Chamber 91 dB
Typical Listening Room 93 dB
Impedence
Nominal 6 Ohms
Minimum 4 Ohms
Input Power
RMS, Clipping < 10% of the Time
Recommended 10-175 Watts
Program 125 Watts
