Am I missing much, Amp / Speaker matching opinion wanted
timetohunt
Quick background of system and useage: RF- 83 fronts, a pair of RW 12d subs, budget center and surrounds (cerwin vegas), Rotel RCD-1072 CD player, Pioneer VSX-94 THX receiver. older Mirantz universal player (mainly setup to play my DVD-As and other Hi-density discs, and another panasonic DVD player setup for DVD-Videos. 75% of what I play are standard redbook CDs and good helping of HDCDs, all mostly in stereo but I do fiddle around with other configs and receiver settings. I often play quite loud, all types of music.
Here is what may be a bit unorthodox, I power the RF-83s separately with a Peavey PV 900 power amp. I like this config because my receiver operates with little stress at the volumes I play at. Stays very cool. To me the PV 900 amp seems to work very clean with no coloration of sound. The thing is that my opinion is rather limited in that I have not tried much else to power those fronts. Just a minimal gripe that the PV900 fan is loud, but at my volumes its hardly a factor.
Do you think I may be missing out on better sound by not having a higher end amp? And reminding that the PV900 application is mainly DJ / PA as opposed to home Hi-Fi. I mean, is there a chance that I could be floored by something in the say $700 - $1000 range compared to the Peavey? (pricing does not absolutely have to be for new amp, possibly used) Your thoughts? Thanks.
GranteedEV
GranteedEV
Depends on just how audible the fan noise is. Even if it's not offensive, it could be masking low level detail.
One of the amps often recommend around here, the Crown XLSxx00, is technically for PA usage. It does however avoid the fan noise issues.
Josuah
I've found some amps to reproduce sound better than others. But I'm in the minority on this web site. My suggestion would be to try some other amps (borrow from friends or try some that offer trial periods) to see if you find an improvement.
That sounds interesting but how will he compare them? You know, how would he eliminate human bias and the placebo effect? I am sure he would want to compare the amps in a credible manner, no?
The question is;Just a minimal gripe that the PV900 fan is loud, but at my volumes its hardly a factor.
If he listens at such levels how will he hear the low level detail?I would think the fan would be off when the low passages are played, no?
jonnythan
jonnythan
The fan raises the noise floor and can mask low-level detail, even in high-volume scenes.
I think not.
The amps will differ in features (fully balanced, auto reset protection/ fuse-less circuit, etc), build quality, country of build (USA, China, Japan, etc), hiss noise, fan noise. :D.
But, from where you sit, say 8-10 ft away, if you can't hear the hiss or fan noise, then it should be all good.:D
If the fan noise is loud, it may be messing with the overall sound quality.
And if you are just looking for our blessings to buy a new amp, you have it as well.:D
Can't blame a guy for buying new amps or speakers.:D
