Sorry Guys,
I had to edit my 1st post, as after severe day & night calibration & head banging, I found a solution to my problems...
So if you want to read, go ahead, but I am the 1st to admit that I was wrong, and there is no shame in it...
I appologize to Yamaha or any one offended in any way by my post + I also wanted to correct any miss-information that might lead to problems to any one who read it...
For a detailed explanation to how I fixed my problems, read the last post...that I will post tomorrow...as I got to go to sleep now...my boss is gonna kill me...it is the 4th day in a row to get to work at 10:00AM
=========== Read on if you want ===========
Hi Guys,
I don't know but I feeling lost in here.....
I had a
Sony STR-DE597 A/V Receiver for quite some time and I was happy with it's audio quality, but one day I decided to upgrade (I don't know why I did
) to a
Yamaha RX-V550....
Damn! It looked excellent, the connections & features (on paper) are far better than my entry-level Sony, but....
Once I hooked it, here we go:
1. The front panel display
illumination is very low + most of the Text &
Icons are very small, most of the time I got to get up to see what I am doing.
2.
My Sub is gone; My Sony Used to make Lord of the Rings shake the room (with sound wave you can feel, not hear), I spent the whole week-end trying to adjust it, but it never got to the level of the Sony
3.
Pro Logic & Pro Logic II, sounds like crap, why? see this:
- Using the Sony, I used to feel the PLII, even in Comedy Series like "Seinfeld", the audience laughter & clapping used to come from ONLY the rear speakers, other Sci-Fi like "Battle Star Galactica" (Note, my Satellite reception is in Stereo Only), I always felt the rockets whiz-by & Ships flying sounds distinctively going from front to back or vice versa.
- Now with the Yamaha RX-V550, I feel all the sounds are coming from the front (esp. the Center), there is only a low echo or humming from the rear, no actual sound movements.
I spent days & nights trying to adjust the levels, distances, etc. trying every Sound Mode they have, none made the PLII sounds like a real PLII (there is no actual sound processing)
Then again, the Remote is bulky and awkward, it is not simple to use....
Ok, saying all that.....
CAN ANY ONE TELL ME IF I AM RIGHT OR WRONG?
Any one tried the Yamaha RX-V550, can any one confirm that?
The subwoofer, Remote & the dim Panel, I can live with it, but the Pro Logic II problem is impossible....
If any one has anything to say please do......
Thanx
WOW, after looking at it, sounds like a very pissed-off guy
