Aluminium concaved drivers
PowellAudio
Can anyone possibly help me? I’m currently in the process of building some speakers and I’m looking for some high quality aluminium (or titanium) concaved mid / base drivers, Ideally 6 inch’s diameter.
I also need to find a good quality aluminium dome (or concaved) tweeters which would be compatible with the mid / base driver.
I know swan speaker (HIVI) produce some however the gold finish would work with the over all look of my finished speakers. I’ve seen loads of other company’s on the market using these but can’t find a supplier my self.
I’d be really grateful if anyone could offer some advice.
Thanks
Bruce
Parts Express also carries them and they are on sale this month...
Just a little comment: don't choose drivers based on look, choose them based on the design of your speaker, because that is going to get you the best sound.
Buckeye_Nut
Call Klipsch!!
They'll sell you whatever drivers you need. The RF-62 drivers are 6.5" and from the new reference line.
They may cost more than buying generic speaker components from parts express, but then again....... you get what you pay for. If this is the type of driver you seek, settle for nothing less than the genuine article!!
WmAx
WmAx
Also, you can always paint the mid range cones using proper preparation/paint if a specific color is required.
-Chris
PowellAudio
Thanks for all you replys and advice, however I have re-read my question and there appears to be a typo....opps sorry!
I'm actualy looking for drivers that have an aluminium finish NOT a gold finish.
the gold one's wouldnt work with my final design.
So dose anyone have any ideas where I can find these?
thanks again
Bruce
silversurfer
Are you designing based on looks or functionality?
PowellAudio
the design is based on both form and function. to be honist I'm just a bit tired of looking at ugly speakers that just sound good.
so this is why i'm looking for the aluminium drivers.
thanks
Swerd
Swerd
I'm actualy looking for drivers that have an aluminium finish NOT a gold finish. The gold one's wouldnt work with my final design.
Madisound sells SEAS drivers. They make a number of very good quality aluminum models in various sizes. Look for model numbers beginning with the letter L. http://www.madisound.com/cgi-bin/index.cgi?keywords=seas What size are you looking for?
Parts Express sells a 5¼" (DA135-8) and a 7" (DA175-8) aluminum mid woofer. Parts Express also sells its Dayton RS series, which are better quality aluminum drivers than the above two, and are available in a wider variety of sizes. All the RS drivers have an anodized black finish.
Swerd
Swerd
I just noticed that you are in London. The real London in the UK and not London, Ontario?
SEAS is a Norwegian manufacturer. Madisound is a dealer in the USA. SEAS products should be available in the UK, but I don't know who that would be. Try looking here http://www.seas.no/.
PowellAudio
I'm in London Uk. thanks for the link. I've been onto the Seas website before but they dont produce the kind of thing i'm looking for.
I really need to find the kind of drivers that RBH use in their speakers. http://www.rbhsound.com/mcseries.shtml
can anyone help?
thanks
