Alphabet soup--HDMI, Component, DVI
I just bought a plasma screen tv, a Pioneer Elite HD 1120, and I would like to put together a reasonable system for video and audio. I have a few questions that relate primarily to how I should connect the components.
I have found that the tv has HDMI inputs. I have read reviews which seemed to find the pairing of the Pioneer DV-59 AVi DVD player especially pleasing when connected via the HDML. Is the HDML connection superior to component video (I suspect the answer is yes)? If so, why aren't HDMI input/outputs available on the AV receivers (or are they)?
I'm not sure how relevant this is but Directv's HD DVR also has HDMI outputs.
Is DVI better than component video or HDMI?
Any help you can give me will be much appreciated.
By the way, what is the USB port for?
