Alexa and multiple rooms audio
dashelter
I have a home theater system already installed with Alexa...I have Echo Dots and Echo Inputs.
For the main living room area, I have an Echo Dot and about 5 Echo inputs connected to different outside speakers and inside speakers.
However, when I connect to Alexa Echo Dot via Bluetooth (for example) to play Youtube music (since there is no Alexa skill for youtube to play youtube music), I am not able to select specific outside speakers to play the music through. It only plays on the Echo Dot. I do not have any wireless speakers. It is all wired.
Is there a gadget I can buy that will allow the music sound to play in selected outside speakers vs only in the Echo dot when I am trying to play youtube music even via bluetooth connected to the Dot?
Same thing for playing music already on my Android Phone.
The problem with Alexa is that if the skills are not there to play music like from Spotfire or Sirius XM, etc..., you have to connect to the Echo Dot via Bluetooth and then play music from the source. But sound only comes out from the Dot and does not give you the option to select the other speakers connected to the Echo Inputs to play music through.
Please help on a best alternative.
Thanks.
