Hello First Post, I am looking into getting a new Turntable that is affordable but has good sound and would be paired well with an affordable Tube Amp. I Currently own a Crosley CR66 which is nice for a office or den but the turntable is very bad and the built-in speakers with no external outs is horrendous. What I am looking to do is have a nice budget listening room to listen to my records.
I am looking into the
Amazon.com: Audio-Technica AT-LP120-USB Direct-Drive Professional Turntable (USB & Analog): Electronics and the
Amazon.com: YAQIN NEW MC-13S EL34(6CA7)X4 Vacuum Tube Hi-end Tube Integrated Amplifier Push-Pull Silver: Electronics 45w per channel as the TOP of my Budget $900 realistically I would like to be around the $600 range if the 10w per channel tube amps are worth the investment
Amazon.com: Gemini Doctor GemTune BL-02 Vacuum Tube Integrated Amplifier: Electronics the self biasing would be handy. But for ~$250 more the Yaqin as a whole lot more headroom I assume but will need to be played louder to saturate the tubes properly? I currently play guitar through a 18w Hughes and Kettner Tube amp which is plenty loud for guitar but dont know tube wattage translates with Vinyl?
Also With the Audio-Technica turntable with a tube amp,"A selectable internal stereo phono pre-amplifier allows the turntable to plug directly to components with no dedicated turntable input." I would assume dont need a pre amp to run it into a tube amp? As far as speakers, I am planing on using my Bose 2001 4-8ohm 50w speakers or my Bose 161 4-8ohm 10-100w speakers. and possibly my Audiosource Dual channel 10band EQ
In order of out-put I think would work well for my budget listening room:
Audio Technica LP120>AudioSource 10Band Eq>Yaqin 45wx2 Tube amp> 2x Bose 161 or Bose 2001
Thanks for any help and advise! please point me to any better products you think would work better for my Budget!
