> I moved the riser out as it was suggested to get the rear row at least 1' off the rear wall...this moved my front row to approx 1' behind the center line of the room. Which of these two suggestions is more beneficial? <
It's true that a seat right up against a wall is a bad location because that's where the peaks and nulls are worst. But whether you're right against the wall or a foot in front of it, either way the sound will be terrible.
The best solution is to treat that wall with rigid fiberglass four inches thick, covered with fabric, or equivalent commercial panels. You don't need to cover the entire wall - just the part behind people's heads, and maybe an extra foot beyond that in all directions for good measure. Then you can move the back row against the wall, and slide the front row back a foot, and both rows will be greatly improved.
--Ethan
