Advice sought for adding speakers from older Philips (FW-v795) system to a Yamaha RX-V377 setup
G
GrowTesq
An AV novice and a first time poster here, not sure if this post should belong on this sub-forum (will promptly delete/edit if not so).
I have Pioneer SP-FS52 Front L/R speakers set up with the Yamaha RX-v377. I am looking to add 2 speakers from an older Philips (mini Hifi Surround) system to expand to a 4 speaker set-up.
Info and specs for the Philips Fw-v795 (hopefully relevant and sufficient):
This is a 2002 system (with little info online barring user manuals), with 4 speakers in all, a main unit and a booster amp. The 2 front L/R speakers connect to the main unit and 2 additional (surround) L/R speakers connect to a booster amp unit (2 Ch RCA cable running from main unit to the booster amp).
Speakers: Front L/R: 6 Ohm, 3-way [front firing woox bass reflex], Booster L/R: 6 Ohm, 3-way
Amp: Front L/R: 2x120W, Booster: 2x110W; SNR ≥ 75dBA, Freq resp.: 50-20Khz, ± 3 dB
More of a newbie here, when it comes to setting up audio, so I would truly be thankful for advice on whether any of the 2 speaker pairs from older Philips system can work with the Yamaha RX-v377 AVR, and if so, which pair would be suitable.
WaynePflughaupt
WaynePflughaupt
Either one should work fine. The worst than can happen is that the receiver will shut down.
Regards,
Wayne A. Pflughaupt
