You are correct, the existing speaker wiring is not conducive to a traditional commercial 70-volt system. Therefore you will need a 12-channel amplifier if you plan on connecting speakers to all 12 of those speaker wires. Try Home Theater Direct – they sell some affordable 12-channel amps.
However, keep in mind that such amps are not designed for the continuous duty, all-day operation that a commercial installation requires. If they prematurely fail, your only option will be professional-grade equipment such as sold by Crest, Crown, QSC, BGW and the like, which will be considerably more expensive.
Regards,
Wayne A. Pflughaupt
