Thanks ShadyJ. I've seen this diagram before. I've read elsewhere that the rear speakers should be about the same distance apart as the front left and right speakers. Those are about 6 feet apart, so that's what I was thinking for the rear speakers. Are you suggesting that they be farther apart than that?
My bigger concern is that, as you can see on the photo, if I install the rear speakers in a wall, I really have no choice other than to install them on the face of the kitchen soffit which will place them about 10 feet above the floor and about 4 feet behind the listening position. Would I be better off installing these in the ceiling and, if so, should I switch to round ceiling speakers? In this case I guess I would install them close to the back wall so they would be about 3-1/2 feet behind the listening position but pointed directly down.
