So, my JVC HX-GD8 has recently developed an issue that I haven't been able to fix. It suddenly stopped playing while blasting music yesterday. The stereo turns on and visualizer shows input is playing, but all speakers are silent. Tested the speakers with 9 volt battery and theyre good, and the main unit's fuses are intact so I am lost. I am not opposed to getting a new system, but my budget is very limited and I know NOTHING about electronics or audio, though I have been doing a lot of research.
My question is, what is the most affordable way I could get the sound I had with my JVC, working with limited space? I only use it for music (metal variants, mostly) and almost always with volume maxed. The tone was really perfect for me, despite the subs dying on me years ago (affectively making it a 160 watt system I suppose?). I have added some more info from the user manual:
Speaker section—SP-HXGD8
Type: 3-Way 4-Speaker Bass-Reflex Type
Speakers:
Subwoofer 20 cm cone x 1
Woofer: 13.5 cm cone x 2
Tweeter: 5 cm cone x 1
Power handling capacity:
Subwoofer: 195 W
Main speaker: 80 W
Impedance:
Subwoofer: 6 Ω
Main speaker: 6 Ω
Frequency range:
Subwoofer: 30 Hz – 970 Hz
Main speaker: 75 Hz – 25 000 Hz
Sound pressure level:
Subwoofer: 83 dB/W•m
Main speaker: 88 dB/W•m
Dimensions (approx.): 240 mm x 457 mm x 407 mm
(W/H/D)
Mass (approx.):
10 kg each
also, it is rated "up to" 10% TDH which I have learned is a bad thing haha
