Thanks to you all for the comments. If i can BMX - you use plex to organise and be a back end foundation and is your player Kodi? If yes -does kodi play all you files and pass thru all the high end files ?
I have Nvidia Shield which has almost all of the above on it. But i think whether i go plex or Jellyfin that i'm supposed to install same on my desktop as opposed to on the Nvidia. can you confirm ?
So, you may want to look in the Media Server sub-forum on these very Audioholics forums for some existing discussion of Plex.
Plex is VERY easy. You need to install the Plex server on a device which is on and running 24/7. In my case, I chose to install it on an old PC I had sitting around, literally doing NOTHING. So, I threw a hard drive in it and installed Plex Server. Plex server runs on any spare computer you have, or can run on your main home computer. It can ALSO run, I believe, on the nVidia Shield, but I'm not sure which specific models support the Plex Server program.
Once you install the Plex Server program, then it will allow you to tell it which directories all of your media files are stored in. You can add additional categories if you would like and you can add multiple folders for each category as you like. You can have your files stored across multiple networked hard drives as well if this is your setup, or you can just point it at a single folder on a local hard drive. So, you have good flexibility and ease of use the setup.
Once the server is installed and configured, which took me about 15 minutes to do the FIRST time I ever installed it. After using Kodi and other apps I didn't think that was all there was to it! Then Plex Server will look up all the information for all the files you have and get cover art and information for those files. It will periodically scan the hard drives for any updates, and will update the file information. For me, this typically happens in less than an hour. So, if I add a new movie to my collection, Plex has it in the library within the hour with cover art and everything else.
For PLAYBACK - You need a Plex player. The Plex player can be installed on a TON of devices. On your phone, on your TV, on Roku, on the Shield TV, on Amazon Fire, on AppleTV, on Samsung, Sony, and most other displays directly.
The player will ask for the login and password you created when you setup the Plex Server and then it will connect to your server. Kind of like logging in to Netflix or any other streaming service. From there, you are done.
This is why I say it is worth giving Plex a try. It is extremely quick to install, extremely versatile with the playback devices it supports, and if you don't like it, you can uninstall it in 5 minutes.
As for playback, it supports 4K video on devices that have 4K video support. I use Roku Ultras for my playback devices and they look really good. Keeping in mind that the quality of the original encode will significantly impact the quality you get out of the playback devices. Time and time again, the Shield is the top recommended playback device for Plex.
My one gripe is the lack of support for ISO files. So, my Blu-ray discs which I had ripped 1:1 to my network drives I ended up re-encoding as lossless MKV files, which Plex supports just fine.
There are bugs, as there are with all the other systems, but there is a very large support community and Plex does address things.
At the very least, this is something which I think people should 'try' if they are interested as the setup is just so easy. I know I spent about 3 hours messing around with Kodi one night just to get it setup and figured out, then I realized I couldn't just play it back easily on my TV. It was designed for 'computer' use. That wasn't at all what I wanted and I didn't find the interface convenient in the least. Plex really solves this.
My emphasis, if it wasn't clear enough, is that it is so easy to setup and try out, that you should do so. Just download the server to your home computer, and set it up, then go to your Shield, or any other smart TV/device in your home and install the Plex player. You can be watching movies or TV shows very quickly.
Some basic questions you can often just Google and the Plex support articles will come right up with answers.
IE: what music formats does plex support
Media Support The following information is about media/encoding support for our Xbox app. General Video Support Content matching the following...
support.plex.tv
