U
urmypal
Which one of the below do you recommend as a center channel for high ceiling living room?
JBL Studio 520c 150w dual center channel or
Cerwin Vega SL45C Quad 5 Speaker
Thanks in advance.
Vj
What are your L/R speakers? I use a 520 with my 590s....
U
urmypal
Glad you asked, I should have mentioned that in my post earlier. Canton 130 speakers package, I feel the center channel that came with this isn't effective, the dialogues aren't crisp and sometimes distorted. I'm using Yamaha TSR 5810 as a receiver. Not sure if my setup needs any adjustment. I appreciate any suggestions on how I can get this setup right?
I was also wondering if I need a better center channel. I do not want to spend a lot and I was debating on the above two models. So, I'm on a lookout for one that could be crisp and work well with L/R speakers.
Thanks!
Thanks!
How do you have your center positioned? Pic?
