Advice needed: Please help picking better near-field monitors
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#1
Help me pick - My current choices (all priced as pair)
JBL LSR2325P - At $320-330
Behringer TRUTH B1030A - $286
AudioEngine A5 - $325
My current preference goes toward Behringers, since they are cheapest of the bunch and I'm very happy with my work pc MS16 speakers.
I'm looking for most neutral sounding speaker, with decent amount of bass (I know that 5" woofers will not replace proper sub) I think I could find local dealers for every one of these, but none have all them in single place, at this price point I'd rather hear AHers or owners suggestions (Yes, I'm being lazy a bit)
bikemig
Ratings
170
#3
I think there are two great things about the A-5s. First, is the sound quality. I recently replaced my A-5s with PSB Image T-6 speakers. The T-6 speakers are, I think, amazing speakers. That said, the A-5s compare favorably to them in the mid range and high but obviously get beaten badly in the low end. Second, the A-5s have a number of useful inputs and outputs (2 minijack inputs, and one RCA out) which makes them easy to with different sources or with a sub.
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#5
Question : despite very similar tweeter and woofer sizes behringer and jbl have a very different xover points. Does it makes any difference?
Also jbl are bit more powerful and dig tad lower ...
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#6
shameless bump... Guys, my deal on jbl's is expiring in 3 days....
I'm starting slowly leaning towards them...
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#10
That's a heck of a deal on the JBLs; I'd consider springing for them at the price if I needed a pair of near field monitors and I'm an audio engine fanboy, :D. Here's a review by someone who thinks they're the best thing to hit the audio world since sliced bread, http://www.amazon.com/JBL-LSR2325P-...2K6M/ref=sr_1_2?ie=UTF8&qid=1309188644&sr=8-2.
There are couple of options- first there these guys:
http://cgi.ebay.com/JBL-LSR2325P-St...ltDomain_0&hash=item43a5e65c66#ht_5081wt_1195
I'd feel that offer of $165/each shouldn't offend them ;)
and secondly I found small site there they have only one, but Zzounds agreed to match and lower it to $164.99 - I can't post the link - since it's one off deal - you need to asked them yourself
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#11
Update: I just ordered JBL's before Zzounds runs of of stock.
with 30 days guarantee I feel pretty safe about
adk highlander
adk highlander
pessimistic optimist
Ratings
1,960 4
#12
Those JBL's look very nice for the price. I have the B2031P's which I have been very happy with in my office. I have not heard good things about the quality of the amps in the active models so the JBL would probably be a better choice.
Edit: I see you ordered the JBL's. Post some pics and you impressions when you get them. My amp in my office has been giving me issues once in a while so I may look at swapping to a set of actives and put the 2031's in the garage I am building.
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#13
Just got home, UPS luckily left them on the door.
Maked room around the monitor... Geez - I should have noticed the weight - 16lbs each - probably a bit of stretch for my tampered glass top computer desk...
Anyway - Speakers to 50% volume, rest of setting defaults...
Windows volume to 25-30% (Creative SB 2 ZS)... first real test: Avatar DTS - Holy Crap - THEY ARE LOUD !!! But absolutely crystal clear.
Bass is unbelievable for only 5" woofers... I need to get some classical flacs to proper test , but for now - I'm blown away...
I'm very happy with them !
p.s: Funny enough my previous pc speakers were also JBL :D - I completely forgot that fact, but they are just really cheap speakers which Compaq bundled their desktop with. (These)
Alex2507
Alex2507
Ratings
9,091 58 3
#16
just noticed that A5 is self powered but not active ... does this really matters?
I always thought active meant self powered or amplified.
... the garage I am building.
Make sure you put in lots and lots of braces. :D
That settles that. :)
I haven't heard the JBL's but out of your other two choices I would have picked the A5's. I heard them up at Jeff's and they produce quite a bit of bass for a small speaker. I'm assuming the 2030A's are similar to the 2030P's I have heard previously.
You know a picture is worth a thousand words. ;)
BoredSysAdmin
BoredSysAdmin
Ratings
5,089 17 29
#17
Active means - Each woofer is powered by it own dedicated amp AND there is active (powered) crossover circuit...
This (more or less) was explained to me earlier after I bought Behringer MS16 speakers for work pc.
The reason I didn't get the A5's - I guess they are too mainstream :D;) Seriously thou - I got my JBL's at same price as A5 and I hope that my don't suffer from typical issues which are inherited by using passive crossover like A5 does..
I promise, as soon as I clean my messy desk :eek:
  • CEDIA
