advice needed on balanced amp upgrades
johnny45
johnny45
how do you think the Outlaw Model 5000x 5-Channel Power Amplifier 750$
compares to the summit hifi usa TW - AD-5180 AMPLIFIER 5 X 180W 8Ω 1100$
which do you think is better
my current amp setup are for my center , fronts , an surrounds are three crown xli 800 an for my subs crown xls 1502
iv been considering upgrading to a Multichannel Amplifier with better sinad ratio to pair with my outlaw audio 976 4k balanced receiver
would in your option sticking with the crowns be best or would i be better served to upgrade to one of these Multichannel Amps
if i sell off my current amps ill have enough to get the outlaw but if the summit better ill save more for that to me better then 750$ counts as 50% better in specs an performance
for my subs the crown xls 1502 is to me just fine but for my new diy subs i want more power an my aim is to get the xls 2502 for the 1200watts at 2ohms over the 775watt from the 1502
as of now my front center an surround specs are a custom a 8ohm twin 10in 3way center Sensitivity: 98dB 600watts rms crown xli 800 bridged , fronts are a pair of 8ohms 8in PL-89II towers Sensitivity: 98dB crown xli 800 at 200watts each, sides are custom 4ohms 10in 2way dayton audio Sensitivity: 93dB crown xli 800 at 300watts each ,
It has better specs than the Outlaw 5000 but are their any reviews with measurements you can share? Who designed/made them for Summit Hifi?
johnny45
johnny45
for the outlaw-model-5000 ther are review an perfomance spec at but he hasnt dont the balanced version yet the 5000x https://www.audiosciencereview.com/forum/index.php?threads/outlaw-model-5000-multichannel-amplifier-review.10585/
also id love to see the same for the tonewinner to ,as it stands im at a real toss up between the idea of saleing off my current amps to fund getting the 5000x as its availability and price is not always a constant id be fine with no amp for the subs as of now ther not even built yet an as i have the drivers an almost all the wood to do so i could save up down the line for the xls 2502, just for now im torn between the concept of either the 5000x or the tonewinner ther both very enticing
if i could get a combind 800$ for my two xli 800 an xls 1502 within the next 4days via offerup id defently go for the 5000x for the even power for all my speakers -the subs
but as of right now at this post the TONE WINER AD-5180 is back up by another 500$
so uhg!!
