Advice needed: bedroom sound system
E
ElCheap0
I have a small bedroom, like 10x10x10 ft. when i do homework and relax and stuff i want to listen to something good. I dont want to get off my bed to change volume or wiggle a wire or something, so bluetooth or something like that would be nice. I can set up any difficulty of system, so tons of wires and junk is fine, also the wire stuff is fine going all over my room.
I just didn't really know if i shold get a soundbar, or 3.1 stereo surround sound (i have no idea what it's called, but its like a surround sound system but only 3 speakers+bass), or some other thing i have never heard of (that's where the rest of you audiophiles come in :).
I would like a micro-usb plug for phone to charge/use with pandora on sound system, but not necessary, also don;t want reciever box for system, but if it's a must, it;s alright.
Budget- under $300. I know, its not much, but's that's what it is
Room for system- i have an old 5.1 surround sound (6-ish yrs old, sounds great to me, just takes too much room, but i like the using the remote from bed.) that takes up too much room. I have 3 furniture pieces i can put speakers on. no more. the bass is too heavy for furniture also, so i can't have a huge bass. the current one (not permanently going to be there) is like 10x20x30 and 20 lbs.
Thanks for all your suggestions and stuff
