Advice for a Home Theater Receiver Upgrade
burnetet
Hey all, long time lurker here. I have had a Pioneer VSX-1020 for about 10 years and it has been a great receiver for 5.1 surround and music. I feel like it is time to upgrade and take advantage of some of the features newer receivers have. My setup is an apartment with a decent sized TV room and I also listen to music in my bathroom and bedroom so figuring out a multi-room setup would be nice. Currently I use an Amazon Echo for music in the bathroom since it is easy to use via voice control. For my Home Theater setup I run almost everything through an xbox for streaming movies/shows. I have some nice Energy RC-50 towers and Energy LCR center/surrounds. I would like the option to also run 7.1. I have started looking but there are a lot of options and I'm not sure where to start. I would like some advice on how to improve my setup and get some multi-room support. Thanks!
jack robert
Upgrading your home theater receiver may be due to the need to switch from 1080p to 4k as most older AVR devices don't support 4K transmission via HDMI. However, this only makes sense if you recently purchased a 4K projector or television and have access to a wide range of 4K content.
Most 4K-compatible receivers on the market today can carry a 4K bandwidth signal using HDMI 2.0, but what you should be looking for is an AVR with an HDMI 2.1 port that is HDCP 2.2 compliant.
HDCP is an HDMI feature that stands for High-Bandwidth Digital Content Protection, with 2.3 as the latest version of HDCP. It's a copy-protected tool for 4K UHD broadcasts, but for this to work, you'll need a range of sources and displays capable of it.
With HDMI 2.1 and HDCP ports, you'll be future-proof as you can stream 8K content as soon as it's available to users around the world as you're also eligible for future firmware upgrades. But with the release of future game consoles like PSK supporting 8k, it would be a step forward to have a receiver that can broadcast 8k content.
When choosing an HDCP 2.2 receiver, you should also pay attention to the baud rate / transmission speed it can support via HDMI 2.0 or HDMI 2.1 and HDMI 2.0a connections for HDR content.
However, if you are not ready to upgrade due to 4K but have access to 4K content and a 4-way display, you can put your content directly into the display and bypass the receiver. You can then run the audio cable from source to receiver for audio processing.
This also applies to smart TVs, which are now suitable for most 4K streaming needs. In this case, you can use HDMI ARC to carry audio to and from your TV and receiver. But at some point you may need to upgrade by adding more 4K sources to your home theater setup.
NINaudio
NINaudio
First, how are you going to do your multi-room setups? Do you want to install wired speakers in these locations? Do you want/need two or three zone support? Some AVR's have 3 zone support but the third zone requires a separate amp.
Second, what is your current living room setup? 7.1 doesn't really work if you have your seating position close to a wall as those extra two surround speakers are supposed to be placed behind the listening position.
