Advice about "padding" my home cinema
Michael_B
Michael_B
Greetings people.
I just randomly came across your forum and i figured i would ask some of you eksperts :)
Im running a 5.1.4 setup with all klipsch speakers, a few days ago i played around with some more padding to get some more echo away.
But when i run the audessy calibration and the height speakers are firing, i here a decent amout of echo, but im not sure where it is. My best geuss is the celling maybe? but im no xpert in this
The small pads under the height speakers where just leftovers from cutting the other ones, not sure if that spot even helps anything.
I know my windows section is a big nono..but i have big curtains on the way to help with that hole.
And my door is also i big reflection area, but beside those 2 areas.
PS : I cant seem to get pics to show in the thread so i hope the links work fine.
Basiclly i wanna make sure i have the basic reflection points covered
Front
Before :
After :
Back
Before :
After :
What i used
The speakers :
Front right/left and surround right/left : Klipsch Reference R-41M
Center : Klipsch Reference R-52
Sub : Klipsch R-8SW aktiv subwoofer 8"
Height speakers front : Atmos Klipsch Reference R-40SA
Height speakers rear : Atmos Klipsch Reference R-41S
Amp : Marantz SR7015 - 9.2
