lets say you have two options, a bookshelf speaker with a 6.5” woofer, or a floor standing speaker with two 4” woofers. I believe the total surface area of the two 4” woofers would be larger than a single 6.5”. It seems there would actually be benefits to this, at least in theory, no?
The theoretical pros and cons I’m thinking of are:
Wider dispersion of upper mids at the xover point, most 6.5” driver crossed over at the common 2.3khz tend to exhibit at least some narrowing directivity, while the wavelength in relation to a 4” driver is relatively large.
Higher breakup point. In addition to the stiffness and mechanical damping properties of the driver material, the greater the diameter, the lower the breakup mode begins.
An overall lighter driver, resulting in quicker impulse and decay times, resulting in a better transient response.
Cons I can think of:
Lower sensitivity, although this is mitigated by multiple drivers.
Reduced bass response, this one shouldn’t be a big issue when placed in a ported enclosure, one should easily be able to get a solid response to 70-80hz. The sub can take care of the rest.
am I incorrect in my thinking?
