I am looking to add more power to my Marantz PM8004 by adding an external amp. Would the Emotiva XPA-200 give me a lot more power than the stock Marantz? It's rated at 150 @8 ohms. I know Emotiva makes good on their specs too. Would I be helping the Marantz a lot or not? I know the Marantz integrated unit does rate good in the current specs... Any help?
The specs of the XPA-200 is interesting. It's transformer is rated 360 VA, assuming an average power factor of 0.8, 360 VA will approximate to 288W vs the Marantz spec of 200W power consumption that usually tells nothing much but would likely indicate it's transformer would be rated for at least 250 VA. The XPA-200 weighs 31 lbs vs the PM8004's 26.4 lbs, but weight does not tell the whole story, it is just one indicator.
So the XPA-200's transformer seems too small for their claimed power rating of 150WX2 into 8 ohms, but it has 90,000 uF of capacitance, that's 50% more than that of the XPA-5 and 2X that of it's bigger brother the heavy weight XPA-2. I suspect this unit relies heavily on the generous capacitance to give the user a lot of short burst power, i.e. dynamic vs continuous, and I think that is a wise and effective move for a $499 power amp.
Base on their power ratings, the EMO should give you about 3 dB more power than the Marantz, IMHO not worth it and in real world application I doubt you would notice the gain. You maybe better off saving up for the XPA-2, that will give you at least 6 dB more power/spl and is a real power amplifier.
