GranteedEV, I'll give that microphone height adjustment a test when I setup again and how much the results vary when I add in 1.5 ft. Honestly, I never really thought of a vertical adjustment to the primary sub but it makes sense to try. My main concern is if I adjust the sub height I'll probably, not for sure of course, be just moving the freq of the null.
Wayne, I've only got two positions in which to place a second sub with a little bit of wiggle room in each area, one is a corner placement, the other has only one wall. I'll setup the 1124 to only allow a narrow freq range near 60Hz to the second sub to minimize interaction, then see what the sweep results look like and of course, how it sounds.
I always prefer to keep it simple but sometimes things need to get a little more complicated I guess.
Steve
