Fuse Issue, I think...
So I popped the top off and checked the fuses. Each board/channel has 2 fuses on it. The lower one, near the power source, looks to be blown. I have actually never seen a fuse like this. It looks like a type of cloth has been woven with the metal around it. So it basically looks like a normal fuse, only instead of just a metal strip in the middle, it looks like a cloth, white/silver strip with a winding of metal around it. The fuse I took out is melted. Do I need to replace it with the same weird fuse, or can I use any 6.3A 250V fuse that fits? Thanks.
Roly
P.S. Should I take the amp away from my father for awhile, or just send him to his room?
