L
lario
All, I'm looking for some feedback please on whether or not I should be jazzed about the old man handing over the majority of his home theatre gear. Specifically, I will be receiving an Adcom GFA-7705 (amp) and an Adcom GTP-860II (pre-amp/processor). Over the years I've used only AVR's (currently Yamaha RX-V667) and I've grown attached to the array of features AVR's have to offer. I can't find a lot of info/reviews on the Adcom items although I believe they (Adcom) make a decent product. I'm not as worried about the amp as I am the processor. It appears a little dated for what I'm used to (ie. no HDMI but rather relies on component, composite, or S-video). I use a PS3 for the decoding of the lossless audio but it doesn't appear I'll even be able to hook it up to the 860II? I'm vaguely familiar with the benefits of separates vs the AVR so I'm thinking I should be jazzed about the amp (GFA-7705 rated at 200W/channel) as I believe (correct me if I'm wrong) this can be hooked up to my Yamaha for the extra oompf! I'll also be adding the old man's front Polk towers (RTI-10's) to the mix which would likely benefit from the amp. Thoughts? Ideas?
cpp
cpp
200 watts x 5 channels into 8 ohms
Power rig circuit topology
Gold Plated 5 way binding posts
Huge torriodial transformers
Power bandwidth 10 Hz –100kHz
12 volt trigger on circuit
Dimensions 8.5 x 17 x 17.5 inches
Unit weight: 69.5 lbs.
Requires 20 amp dedicated circuit
If it's free and it's working without any problems, sure. Your Yammy has pre-outs so enjoy. Can't beat a free amp in this economy agree skip the pre-pro.
Swerd
Swerd
The Adcom amp will very likely be a benefit. If nothing else, you can use it to power all, or some, of your speakers. Your Yamaha does have preamp outputs for all the audio channels. When I switched from powering my front speakers by a modest sized Denon receiver to a larger amp, I noticed two things: 1) bass was more potent and cleaner, and 2) I could listen at louder levels while it sounded less distorted. It was louder without seeming to be under stress.
Whether the GTP-860II preamp/processor will also be better than your Yamaha is unclear. I did find the owners manual for it online. Maybe you have already seen it. Whether it makes an audible difference compared to your Yamaha, or whether it is more "user friendly" to you is hard to say. All I can say is try it. You may only know those answers after using it for a few weeks.
If you use a PS3 to decode lossless audio, how do you send the audio to your Yamaha? By HDMI cable or RCA audio cables? The Adcom lacks any way to decode lossless audio, but it will handle decoded audio sent by RCA audio cables. It may be a bit more complex to hook up, but it is not likely to affect the sound.
As to the Polk speakers, try them out and compare them to what you have.
ski2xblack
ski2xblack
jazzed, definitely
That amp looks like a beast.
timoteo
timoteo
Congrats!!
Dude you SCORED on that amp!! Ditch the pre/pro & juice up your good ol' Yammy!!!
Adding an amp to a well stacked AVR is the new way to go. You get the great feature set from the mid/high receiver yet all the power from a quality amp....best of both!!!
Hook it up & enjoy!!
PS: make sure you run audio via HDMI & set the output on the PS3 to bitstream or direct this way your Yammy decodes the HD audio & you get to see them pretty lights :)
