Acurus A-100x3 how to connect?
  • Thread starter Thread starter razzia
razzia
1
0
0
Hi,
ive bought an Acurus 100x3 amp and want to connect it with german fuse ratings (220V 50Hz). Ive seen an info on the backside of the amp:
Sorry, bad image. here the text:
fuse ratings:
120V AC 60Hz
8A S.B.
230V AC 50Hz
T 4A/250V
1200 Watts Max.
How can i change to 230V AC 50Hz?? there isnt any switch!?
Another problem: ive pulled out this:
it was on the backside beside the fuse. there are four chances to put it in. but whats the right choice?
Thanks for your help!
Best regards,
Stephan
PS: if someone has the manual, pls msg me! the docs on the klipsch homepage doesnt contain the whole manual.
