Searching throughout the web for ideas I keep running across “Acoustical Art”. Simply described as speakers mounted into PVC fittings. They are gorgeous! Way too expensive (like $2,000.00 a pair)!
I searched this site to see if anyone has discussed this topic and came up with no results so . . .
What do you think? Is this a decent DIY project or what?
www.acousticart.com
I have found only one DIY project similar to this. The photos are thorough enough but seriously lacks technical verbiage and detail:
http://groups.msn.com/TheLauFamilyWebSite/rearboxsterspeakers.msnw?Page=1
I imagine that if the appropriate size speaker and the correct amount of airspace is used, it should work just fine (my ignorant assumption). What do you guys think? If anyone knows of any DIY pages RE: a similar project pleas post.
