Can you be a bit more specific about where you end up for best bass and where you end up for best imaging? Also, what do you consider proper imaging? I'm just trying to get a handle on what you're shooting for.
Do you already have some of our products - if so please post what so I can see what we have to work with.
The side reflections are important but the ML's aren't as wide dispersion as some other speakers - and certainly not wide at all in the vertical dimension.
Bryan,
Thanks for the response and I'd be happy to take your help.
In terms of imaging, I'm looking for the correct sound stage proportions, whether its large or small. Drums and cymbals are the best example that I have. When listening to a drumer, at times the cymbal crashes are located way out of proportion of the drum set, like the drummer has to reach over 10 feet to the guitarist or bass player to hit them. Hi-hats can sometimes be in the same situation, they seem out of place. I just want imaging/soundstage that is in correct proportions for all of the instruments, reguardless of whether it's a big or small sounding recording. Sorry, I'm not sure how to explain this better.
Speaker location: To be honest, I have not be as diligent with keeping track of what specific location is the best for imaging vs. bass. Here's what I do know. I'm getting pretty good bass and imaging from a position that is 1 foot foward and 6 inches out (or closer to the side walls) in respect to the speaker position on the diagram on my first post. Relative to the diagram position, if I back the speakers up roughly a foot and move them in towards each other imaging gets more in line, but the bass suffers. Again from the position in the diagram if I move them towards the outside walls, bass improves but I had imaging issues, from what I recall.
No, I do not have any acoustic treatments.
I understand about MLs side reflections from sound emitting from the front of the panel not being so important, what I'm more concerned about are rear emitted front wall to side wall reflections as my speakers are slightly toed in.
Bob
