G
gato
I tried finding reviews on AE's Aego T 5.1 on here, but I did not find much. Does anyone know what these sound like?
Thanks
G
gato
I saw the website, but I would rather have a unbiased review. I know that maybe hard to get because everyone hears things differently, but I figured I would like to know if any audiophiles have heard anything about them.
Thanks
Davemcc
Davemcc
I have the AEGO-M. Based on my experience with this system, I would heartily recommend the AEGO line for a small, inobtrusive system. The AEGO-M will fill a large room and sound good in the process. My impression of them is that it's a very high quality product and worth the money. I've had them a couple years now for my computer monitors with no regrets whatsoever.
G
gato
Thanks Dave!!
I was looking at the Aego T 5.1 system because of their small footprint. I like the alloy cabinet (not plastic) and the look of the speakers. They should also pass the WAF test :)
The technical specs look good to me (novice):
Aego-T Satelite
Frequency Response: 100Hz to 20kHz ±3dB
Frequency Range: 75Hz to 30kHz @-6dB
Power Handling: 100W peak programme
Amplifier Compatibility: 25 -100 Watts into 8 Ohms
Nominal Impedance: 8 Ohms
Sensitivity: 86.0dB for 1 Watt at 1 meter
Dimensions (H x W x D): 202 x 124 x 146mm
Aego-T Subwoofer
Low Frequency Cut-off:-6dB @30Hz
Amplifier: 200 Watts into 4 Ohms
Low Pass Filter: 2nd Order at 250Hz
Input Sensitivity: 300mv for rated output
Dimensions (H x W x D): 390 x 360 x 420mm
Davemcc
Davemcc
gato, I just cross referenced this with your other post. There are for your 22' x 15' room. I guess. I did have to use the M in my 11' x 14' living room in place of my main system when my Integra was gone for a few months for warranty replacement. I found it to be a satisfactory experience but I can't say for sure how they T will handle your much larger room.
The satellites are very small but they are also quite solid and unexpectedly heavy for their size, at least on the M (not sure about the T). My gut tells me that it's going to be alright but I do suggest that you try to keep the option open of returning them if they aren't quite up to the task, just to be on the safe side. My experience suggests that they will do fine but I can't predict what your ears will tell you or how they will interact with a room that size.
G
gato
Thanks Dave. Are yours 5.1 or a 2 system set up with the M series?
Davemcc
Davemcc
The M is a 2.1 system. Actually, it's a 3.1 with L/C/R analog in/outputs
