Not might, it will change the sound. At most listening levels, the combination of surface materials causes multiple reflections. Some of the mid-range frequencies will hit the ceiling or floor and reflect to other surfaces without losing enough to make them inaudible, so they'll adversely affect the sound quality. If you want to hear a rough example of how it may sound and you can get some plywood, lay that on the floor in front of your speakers, extending most of the way your listening position. It will definitely be more reflective and if the room is large enough, it will cause the sound to actually echo. Flutter is one problem that makes any sound with sharp transients into a problem. I carpeted my place specifically because I had hardwood floors and it was impossible to have good sound. For sounds that have a soft attack or low volume, it's fine but once it reaches a certain SPL and for sounds that have fast transients, it's not.
