First off, don't run them on the B connection. If they are 8 ohm, you are now making the amp drive 2, 4 ohm channels. The A and B come from the same amp. Its no different then hooking up 2 speakers for 1 pair of binding posts.
If you have your rear channels open, hook them up on there, and boost the level all the way up, or to what level the fronts are at. This way, you are not dropping the impedance in half.
SheepStar
