AAARRRGGGHHHH My Ipod died/need storage advice
jamie2112
Dag nammit my Ipod died.Sad face on the screen and Apple support says its dead.Well I guess I will get the 160 gig and the Applecare $59 plan.....I can carry my whole collection with me now.I also want to go get a 1TB HD for my backup.My 250g Western Digital is sucking.Any thoughts as to a great portable HD?????
lsiberian
lsiberian
Western Digital makes the best hard drives in my experience, but if you are listening off an external hard drive you will have issues. I've never found a hard drive that stayed connected to a computer's USB port without skipping a beat and I've tried Maxtor's, Iomega's and even the one I built. The issues do tend to be windows related though. What version of Windows are you using?
jamie2112
I am using a Macbook.
Schupo
100% of my music is stored on a 1TB Fantom Drive external. My 300+ gig music collection (much of which is FLAC, about 20 megs a song) plays seamlessly, even on shuffle mode. It's usb 2.0. I've also got this computer hooked into my tv, and i regularly stream 12 gig mkv files directly from the HD to my television, and it rarely skips a beat.
Why do you want a portable hard drive? If the disk is for your backup, you don't want to move it around, as you'll likely damage the drive in transit.
For external drives, I prefer the Seagates. Most of the externals should be able to be made to work with Macs too or have a model that is.
While WD makes good drives, their externals have tended to have a high failure rate.
He's a sound guy, so he is on the road a lot. My guess would be to have it with him while traveling?
jamie2112
You are correct John thanks man.....I just bought a Seagate 1tb firewire esata version.
Sheep
Sheep
I would have gone western digital, the Black is a solid unit. Props on E-SATA though.
SheepStar
