A500 volume control
mike c
mike c
i noticed on the front of the A500 there are two dials ... will those work as volume controls?
I plan to use an A500 for PC speakers (of course with software volume control)
Do I still need a pre-amp? or will those two dials work?
The Audiosource Amp One/A that I had had the same thing. They are gain controls so you can level match each channel, but they gave enough control and easy access that you could use it without a preamp. I'd guess the same for the A500.
Is this little baby contagious? :D Seems like it is getting very popular around here.
As Jgarcia indicated about those gain controls. Some other amps have them/had them so they would work the same on a power amp. Enjoy.
