A very weird request for a Crestron Panel Number
G
Gatsby191
Okay everyone here goes:
Anyone who can get me the correct answer to this one, is the master! I am totally lost and desperate at this point. A FORMER friend gave me a Crestron Touch Panel that he had only used for "Demos", on some high end jobs he had done. It was a pretty cool gift, and I'd like to use it to control my new Home theater room eventually. (as soon as I can afford the Processor and the programming). Well, there is no indication of which Model Touch Panel this is. All that is evident is, that it is a Crestron, and it's wattage, and some other irrelevant info. I also have the base it rests on, but the power cord is no where to be found. I'm pretty frustrated about that too. The only hint I have, as to what panel this one might be is: My former friend had indicated at least a dozen times how surprised he was to see "Tony Soprano" using this same exact Touch panel on one of the episodes he had seen, when the "Damn thing wasn't even out yet" (for public sale). I leave my fate in all of your hands...:confused:
Thanks alot!! Joe B. Warwick, NY
Have you asked your friend? Been to the Crestron web site or call them? Maybe you can email them a picture and they should know?
G
Gatsby191
Pictures of the Crestron Touch Panel
This is the Crestron Touch Panel that I can't figure the model number on, or the right processor(S) to use on it. Won't need a super "revved up" processor because I will only be controlling my home theater room with this touch panel. 2 light switches with dimmers, a plasma. an A/V receiver, BD/HD Player, a SACD/CD player, and a playstation 3. One of Crestrons lower based processors should be fine. Also, the room is 10 X 20.
Thanks all! Joe B.:confused:
You may need to take better pictures and maybe get help from the maker with those pictures? Do you see a serial number anywhere on it?
Adam
Adam
...maybe get help from the maker with those pictures? Do you see a serial number anywhere on it?
I think that's the ticket. Creston should be able to help you out.
You've probably seen this, but there's a touchpanel reference guide located here. I didn't see anything that looked exactly like yours, though.
