I could be wrong but if you are wanting to use your Bluetooth headphones to listen to your tv, you will need to hook up a Bluetooth transmitter to the tv. The device that you referred to is a Bluetooth receiver. Your headphones are already receivers so you just need to find a transmitter instead. They are cheap and easy to find online. I hope this helps.
