What you're saying is probably true, but I don't have the 8033, I have the dual core 2.0. I've looked through the dual core 2.0 manual and couldn't find an adequate explanation for my problem, maybe you'll have better luck if you have the time. What you're saying makes perfect sense, I'm just not sure how it translates from that unit to my unit. I know you can adjust the digital headroom with the one I have and choose an input sensitivity. Do I need to increase the digital headroom? Do I still need to decrease the sub level on the receiver?
Thanks for all the help.
Oh and here's the manual for the one I have if you get a chance. I think the menus changed slightly because I just installed the latest firmware, but it should be pretty similar.
http://www.dspeaker.com/fileadmin/datasheets/dspeaker/AntiMode20DualCoreEng.pdf
Thanks for the correct manual.
This unit does not have the, what I would regard as the essential monitoring, the other unit has.
Your problem is common with all equalizers and devastating with digital ones as you are finding out.
These issues are addressed in the manual in several places. This will be a hard climb but not impossible without instruments. However a dual channel scope, signal generator and FET VOM would be very very helpful.
When you are into complex more reference type systems like you are, a substantial investment and education in using test equipment, is in my view part of the basics. I have said this many times before, but it falls on deaf ears.
Here are the relevant parts of your manual.
Use the manual channel balance adjustment to match the levels of the left and right
speakers. Changes in this dialog take effect immediately. Press the OK button on the
remote to accept the new adjustment or press the BACK button to discard changes.
All internal processing is performed with 32- or 40-bit accuracy with the appropriate
number of bits reserved for headroom. However, if emphasizing (amplifying) filters are
used, some input signals could cause saturation / clipping at the output. The unit
automatically calculates the best headroom setting from the gains of the active filters.
However, if you only use the analog input and do not use the full input range, you can
change the headroom setting to a lower value. If the automatically calculated value is
too small (causing clipping at output), you can manually increase the headroom value.
The headroom value is automatically re-calculated any time you calibrate or change
filter settings, so remember to re-do your own adjustment in these cases.
When performing calibration in the advanced mode, you can select different dip
compensation modes: normal, maximum, or no dip compensation. Using the
Compensation adjustment you can manually increase or decrease the lowpass shelve
filter effect that was automatically determined by the calibration. Note that this
adjustment does not affect the before / after measurement display, but you can
perform a user measurement to determine the best value.
Notice: channel balance, headroom, and dip compensation values are associated with
the current sound profile.
The Volume trim menu allows compensation of different volume levels between the
digital and analog inputs. For example, if the digital input is subjectively louder, adjust
the volume trim value towards the left side until the volume levels are equal. Changes
in this dialog take effect immediately. Press the OK button on the remote to accept the
The Input sensitivity setting adjusts the maximum allowed voltage level of the analog
input. Default value is high sensitivity. Use the low sensitivity setting, if you connect a
device which produces very high voltage levels and you get clipping warnings.
Notice: Input sensitivity and volume trim are global settings, i.e. the values are shared
by all four sound profiles.
6.Advanced Calibration
Advanced calibration gives the user more control over the calibration parameters. The
procedure is similar to the typical calibration, but with some additional steps. Refer to
”Typical Calibration” section of this manual for an overview of the basic process.
To perform the advanced calibration, choose the Advanced Calibration option at the
Calibration menu.
➢ After choosing the relevant speaker configuration, the extra settings dialog will
appear.
Level compensation affects compensation for wide dips in the bass response.
Compensation has three levels, “Off”, “Norm” and “Max”. If the setting is “Off”,
no compensation to boost dips is applied, and the bass level remains as low as
it would be without room effect. This gives maximum headroom for the user to
design custom boosting filters, such as House Curve or Parametric EQs. The
“norm” setting applies a mild compensation, which is the same amount that
“Typical” calibration is using. This setting usually gives the best audible result as
the perceived level of the bass is closer to the uncorrected average bass level
than with the uncompensated “Off” setting. When selecting “Max”, maximum
compensation is used, which gives about +2dB more gain for boosting filters.
This setting is beneficial in spaces where part of the problem is the general lack
of bass, possibly resulted by the absence of proper acoustic barriers. It is good
to remember that destructive reflection nulls can not, will not, and should not be
attempted to be corrected by any DSP.
Note: you can also adjust the compensation level afterwards from the
Compensation setting in the Audio Settings menu.
This is the most important part off all.
”Clipping Detected”: this warning is displayed on the home screen in two cases.
1.”Clipping Detected” is shown when the Anti-Mode 2.0 Dual Core detects that the
analog input signal has reached the maximum input voltage level, causing the
input to be clipped.
Check the output settings of the device you have connected to the Anti-Mode 2.0
Dual Core analog inputs. If you can not reduce its output level, set the input
sensitivity to low in the ”Input Settings” menu. If this does not help, you can try
using the RCA inputs instead of XLR inputs, or use external attenuators.
2.”Clipping Detected” is also shown when there is a possibility of clipping at the
output stage, which could compromise audio quality.
Usually the reason for this warning is that too many boosting equalizers are being
employed. To overcome this, increase the digital headroom value located in the
”Audio Settings” menu. Sometimes also decreasing the input gain may help.
In addition I would make the following observations. Digital clipping is much more serious than analog clipping. From your description you have digital clipping. Whether the monitoring in the antimode detects this I don't know. Most likely your screech is the only warning.
The specs do not say the input level for a specified output on pass through. (No filters engaged). Even worse it does not specify input headroom. Nor does it specify the output headroom.
Equalizers present special problems as you don't have a situation were x input voltage gives y output voltage. The reason as that there are bands of boost. So if an input signal of a volt is boosted between say 40 and 50 Hz then the output in that pass band will be 2 volts even for a zero gain device. If it is boosted 10 db then the output in the pass band will be 10 volts and cause trouble not only in the equalizer, but likely will run the amp input stage out of headroom let alone the power stage.
So here is what I would do. I would advance the controls on your Crown fully, max it out. In that situation 1.4 volts at the input will produce maximum output of you Crown amp. Now lower the LFE output to balance out the input. Note that you can not do your calibration at those settings.
Do the calibration with the Crown controls in the mid position. Then advance them all the way, lower the LFE output to the right range by ear or spl meter and then do the receiver calibration.
If you still have trouble, you will have to interrogate the antimode and look for areas where it has applied a lot of boost and manually reduce the degree of boost. As stated in your manual you may have to build external attenuators. If you get to this point instrumentation is strongly advised.
I could not set up my system without this type of instrumentation. Use of it is a big reason, my rig sounds so clean and effortless.
If results are not satisfactory, then you need the instrumentation I described above or just ditch the antimode. Despite glowing reviews, this unit may well be designed with inadequate head room and my be a less than satisfactory unit.
