W
Weaverj
I have a problem with the sound coming from my plasma TV. Bear with me while I explain the background.
My TV is a plasma 1080i Panasonic that is hung on the wall above our fireplace. The A/V technician that installed the wiring and the conduit for this TV turned out to be an idiot - in retrospect, of course
The conduit he installed was too narrow, too long, and too convoluted for the purpose it was to serve. The conduit runs from the back of the TV to our cabinetry where the cable box is housed and requires approximately 20 ft. of cable to connect the TV to the box.
Enter the electrician who was serving as our sub contractor for the house and who volunteered to replace our A/V technician. Initially we used HDMI cable to connect the TV to our digital cable box and this worked well for a month or so following which the HDMI failed. Our electrician blamed the HDMI failing on the tortuosity of the conduit and the resulting torque that the HDMI connector had on the cable box. Irregardless, ultimately it was decided to use component video cables as the component cables were deemed to be less subject to torque and more stable at the connectors.
I agreed to this but mentioned to our electrician that we would also need to run RCA audio cable as well as the component video did not carry audio. He seemed a little confused by this but eventually discovered that I was correct and agreed to run 'some audio' cables as well.
Finally, upon finishing (fishing the wires through the conduit was a considerable exercise ...) he showed me how the TV worked. It appeared to work fairly well. I did not inspect the wiring at that time.
Over the subsequent several weeks I have noticed that when I am watching any program that has background noise (e.g. crowd noise during a football game, music, etc.) that the spoken word is drowned out by the background noise. When I turn the volume up loud enough to hear the spoken word, the background noise, music, etc. becomes almost unbearable. If I am watching a program that is featuring only conversation, the audio seems perfectly fine.
I went on to look at the connections on the cable box and noticed that we have two component video cables running to the cable box from the TV. One of them obviously carries the video (r,g,b). The other one is connected to the red/white audio jacks. Specifically, the red from the component cable is into the red audio jack on the cable box. The blue from the component cable is in the white audio jack on the cable box. The green cable has been left disconnected. In other words, the electrician used a component video cable to carry the audio.
In addition to the above, if I move the cable box even slightly the video and audio feed is lost transiently.
So my questions are these:
1) Is the connection as I've outlined it above a valid way of carrying sound (i.e. through two of the three component video cables)?
2) If so, then why might I be getting the odd and overwhelming background noise on my TV?
3) And, if the A/V connection is so fragile as to be lost quickly when any movement is introduced at my cable box, might there be something wrong with the connectors on the cable box itself?
I haven't yet asked my electrician these questions as I know that he is good electrician but I also think that his knowledge of A/V connections/components is not very good.
Thanks for your consideration.
JW
JW
