A receiver that allows stereo or surround sound?
Billmelater
Hi, everyone. I’m old-to-stereo but new to surround sound and the newer receivers. I would appreciate some advice on how to move from an “older” configuration to a newer one.
I currently have a single receiver (Yamaha R-8) that serves 2 purposes:
  • Traditional stereo : Polk RTA-11T speakers, Sony CDP 608ESD CD player, ASUS netbook for mp3, wma playback
  • HDTV: with Cambridge Soundworks Ensemble speakers (2 small + subwoofer), Sony DVD player
The systems are in different ends of the same room and the speakers are selected via the Speaker A/B switch on the receiver. I realize this is less than ideal but it’s what I have to work with. The main use of the system is stereo listening.
I would like to upgrade the receiver (looking at Yamaha RX-V671 for example) and TV speaker system (surround sound) but I can’t find a receiver that can accommodate this combined setup (A/B switches are soooo passé). I’d also like to add a powered subwoofer to the Polk speakers. Receivers with multiple zones seem to place limits on how a second zone can be used (analog sources only) and don’t have provision for a subwoofer. It would work if a receiver with “scene” buttons could be configured so that one scene is stereo listening and drives the Polks plus a subwoofer but I haven’t been able to determine if that’s possible from the documentation.
Am I going in the wrong direction here? Are there “surround sound” speaker systems that are musical enough so that I don’t need the Polks anymore? These would have to be much smaller than the Polks because of where the TV is.
Thanks for any suggestions.
markw
It's to bad you refuse to accept using A/B switches. That would be your simplest solution. Add a powered sub-woofer with speaker-level inputs and you'd be all set.
Pity...
Oh, you certainly can fine multi-channel speaker that do music very well, but they aren't necessarily cheap or small. The way to find them is,when shopping, use music as your test source, not a movie soundtrack. If a speaker does music well, odds are 99.99/100 it will do HT at least as well.
Oh, and you might want to forgo using a subwoofer in the selection stage using music. A sub can be added at any time.
Billmelater
Thanks. I am considering an outboard A/B switch. I just wish there was a receiver with it built in. And I hadn't thought about speaker level inputs for a subwoofer but I should have since that's what the Cambridge set does.
markw
As far as I know, A/B switches on AVR's aren't difficult to find. In fact. I'd say it's probably more of a task to find one without them.
