It is active on my SVS sub. And I agree with Sholling that that should be true of any powered sub.
I have found that by fine tuning the AVR level and the sub level you can ahieve the degree of "LOUDNESS quality" you desire. Example you don't want to set you dB gain of 11 on the AVR and then barely turn up the volume of the sub. I have found it is better to be about 1/2 to 3/4 on the sub and set the AVR to the resulting sub SPL level you desire. Usually about 0-3dB on the AVR and 1/2 way on the sub is a good place to start.
Peace and Good Rumbling Sub Sound,
Forest Man
