A Portable, More Seamless Alternative to the RCF Evox 8?
Regev
Regev
Hello,
I have a sweet RCF Evox 8 active column in my living room (it often goes outside to my balcony). I connected it to a Logitech BT Adapter to stream music through Spotify on my phone. However, the system is quite heavy, and I feel like it's an overkill for my uses - its either inside the home (where the volume knob is REALLY low, otherwise it would kill us), or outside in my balcony (about 100 square meter), where it is outstanding, but just very heavy to carry. Even outsdie, the volume knob is about 30% of the way. This is my outdoor setup (Evox 8 to the left):
I thought about selling it, and getting something with a similar audio quality (but much smaller, because I don't need all that power), and with built-in WiFi or Spotify, etc - so that I can stream music without the need for a Bluetooth adaptor.
Is there any such beast? Anything that you recommend?
Thanks
Regev
Regev
Yep :)
Is there any WiFi-enabled, home-oriented speaker that would give me similar sound quality but without all that size, weight, and available power? I really don't need all that juice - the volume knob is always at the very lower end, because these speakers are a beast. Way too strong for a home.
