A Pioneer 1014 with 6 Ohm center?
farscaper
farscaper
Anyone see a problem with a 7.1 setup using the Pioneer 1014 receiver and a 6 ohm center speaker? The other speakers are running 8 ohm.
Thanks, :rolleyes:
BuddTX
Can't say for sure but . . .
The 1014 is THX rated, and someone else told me that there is a requirment to drive a 3.6 ohm speaker at rated output.
JoeE SP9
JoeE SP9
I believe the 3.6ohm requirement is a minimum. Anything higher should not hurt. :cool:
farscaper
farscaper
Just got the receiver on Friday. The manual even makes it known thats its not be a problem. The receiver even has a 6 ohm setup if necessary.
Thanks,
