A NewB's Introduction
snatchss454
Hey all,
This is my first real post and I wanted to say hello as well as thank you. Ive been lurking here for about 3 weeks, just soaking up all the info, reading reviews, getting ideas on how I want my HT set up, what features I can live without and what parts will work best with each other.
Based on the info I read from this site as well as getting some second or third hand equipment I think I've pieced together a nice system. Please lend your opinions....
Heres what I have so far:
Sub - HSU VTF-3MKII
Fronts - Polk RTi10
Receiver - Denon AVR-3806(tough descision between 3806 and yam. rx-v2600)
Amp - Outlaw 755 ....Thanks to another board member :D
Heres what Im planning:
Center - Polk CSi5
Rear/Back Surrounds - Polk FXi3 x's 4
Do you all think its worth the extra money for the 2 extra FXi's for the back's?
Im sure once the rest of my gear gets here Ill have many more questions.
Thanks,
Shane
xboxweasel
xboxweasel
Personally I went the 7.1 route since the receiver could and I did not want to take a change on not being able to buy the two back surrounds at a later date.
Since so few movies are recorder in 6.1 or 7.1 I hardly get to use that feature. And when they are in I do not notice much of an improvement.
The 7.1 feature shines when I listen to CD's in 7 channel stereo. It really helps to fill a big room when I have company over. :D
snatchss454
X,
Thanks for the reply. My room is not that large so I think 5.1 will be fine for me. Thanks for the input.
Shane
snatchss454 said:
Hey all,
Shane
Welcome.
Before you jump on these amps, why not just wait, put the system together, get it calibrated, properly placed, etc, and live with it for a while.
Then, we can discuss the real needs for added amps.
AVRat
AVRat
The rear surrounds can make a difference if you have the space. What are your room dimensions and where is the seating located in relation to where the rears would be positioned? You're putting together a nice system.:cool::D The amps will definely be needed to power the RTi10s.:eek:
snatchss454
I will post up a dimensions and seating layout later tonight. Mtrycrafts thanks for the post, but I already have the amp.
Gotta run to work. Will post more later. Also thanks for the welcome.
Shane
snatchss454
I was thinking of putting the tv on the 8ft 4in wall so that I could put more distance between me and the tv. Which will allow me to set the speakers up better, maybe with the sub behind the couch. Also to clarify incase I worded it improperly, I have everything except the center channel, surrounds and maybe rear surrounds.
Shane
snatchss454
Oh I forgot to add that I have 8 ft high ceilings.
