A newbie question about amps+surround
  • Thread starter the Dark Canuck
  • Start date
the Dark Canuck
Hi all. Thanks for the great resource, and for those that take the time to answer newbie questions. Much appreciated.
I would say that I am about a year away from buying a pretty nice system (say around $8000, not including tv). But I am completely new to this (though not to loving music, of course). So my confusions have already begun. First, I am interested in a nice movie experience, but the focus will definitely be on listening to music. Is it possible to experience good movie viewing without going surround? For instance, I am so far very impressed with this intergrated amp: DK design group's VS-1 Reference MKII. Now, unless I am totally confused this amp will drive two speakers, not a surround system. If I purchased this amp, only to want to go surround, would that mean chucking this piece of equipement? Is there an additional component that could be combined with this piece if I decided to go surround? Or am I just really confused??
I think I'll leave it at that question lest I write a book. There'll be plenty of time for further questions over the next year :D .
Best,
-tDC
F
flyv65
Nope, you're not going to get away with addons-the VS-1 is a two channel integrated amp. If you want surround sound you'll be moving this deck into the den, or posting it at Audiogon.
Bryan have you looked at the Arcam websitefor multi-channel integrated amps?...
Buckeyefan 1
Buckeyefan 1
He is correct. Start shopping for a high-end surround receiver, or mid-grade receiver with a separate 2 channel amp, depending on the efficiency of your speakers. $8000 is a large budget, so you should be able to put together an ultimate system in that price range. Timber matching is important with surround sound, and finding excellent sounding stereo towers isn't easy when you must incorporate the surrounds. If you find the towers you absolutely love for music, then getting their surround counterparts should be a walk in the park. I highly recommend a full 6.1 or 7.1 setup for movies. DTS ES Discrete 6.1 just isn't the same in 2.0 stereo. With a high end surround receiver with multiple zone controls, you can eventually put two ultra high end towers in one listening room, and run a surround system in your theater room. Some even allow both rooms to play at once. Visit your local high end dealers and start listening to your personal cd's. You'll notice differences in speakers right way. The best way to demo speakers is to cross them off your list if there is something you find wrong or missing. They'll all sound good, but only a few will match your musical tastes.
Rock&Roll Ninja
Rock&Roll Ninja
Or you could just watch movies that are mono or 2.0 (Robocop, Sleeper, anything made before 1976, etc etc)
